Topic: Sampler gain
Is it possible to map a knob to the gain adjustment of the sample editor window?
if so whats the script?
thanks
geposted Sat 11 Nov 17 @ 5:40 pm
No script afaik, no script for any popup window, I always felt that the popup windows don't do vdj justice.
I can see that there'd be difficulties making those windows skinable scriptable panels, but I'd hope it be something looked at.
geposted Sun 12 Nov 17 @ 12:47 am
if i could use a knob would be much easier to set volumes .....hell maybe a slider instead of a knob on the gui would be better and easier to set
geposted Sun 12 Nov 17 @ 1:25 am
use this in the controller custom mapping...
sampler_volume_master
Map this to a knob on your controller
geposted Tue 14 Nov 17 @ 4:17 pm
Thanks but I was looking for gain not volume
geposted Tue 14 Nov 17 @ 5:46 pm
