Hello,
When I tag a song as "First Seen" with a date earlier than a certain year, it doesn't SORT the songs correctly by that field.
If I tag one as First Seen 1957, it sorts correctly. But if I tag a song as Frist Seen 01/17/1937, it will SORT as First Seen more RECENTLY than songs with today's date.
See screenshot for example:
I use the First Seen date as I'm sorting music, I find it more accurate than using the Year field.
geposted Thu 16 Nov 17 @ 12:25 am
Sean Arenas wrote :
Hello,
It's also putting 1942 as seen earlier, so the date is somewhere between 1942 and 1957.
geposted Thu 16 Nov 17 @ 12:41 am
you should be tagging with this format
YYYY/MM/DD
so this date 01/17/1937
would get tagged like this in VDJ 1937/01/17
that is if you expect it to sort properly :-)
YYYY/MM/DD
geposted Thu 16 Nov 17 @ 1:39 am
Will be fixed
geposted Thu 16 Nov 17 @ 6:00 am
YYYY/MM/DD
YYYY/MM/DD
If you see my screenshot, that's how they're set.
geposted Thu 16 Nov 17 @ 11:11 pm
Adion wrote :
Will be fixed
Thank you!
geposted Thu 16 Nov 17 @ 11:12 pm
sorry my old eyes couldn't read the small screen cap so i just went by what you had typed :-)
geposted Fri 17 Nov 17 @ 12:52 am
Good point, that is very small text in the screen cap!
geposted Fri 17 Nov 17 @ 1:11 am
