If, for example, I have 4 cue points already set and I change the Type for Cue 2 to Action and enter cue 3. The song will happily jump to cue 3 when it reaches cue 2.
But, after doing so, if I press any cue on my console (Pioneer DDJ Ergo K Limited) it creates a new cue point or moves the cue number to the current place, instead of playing from that cue point.
eg, song plays, gets to cue 2, jumps to cue 3. I then press cue 4 on console, instead of jumping to cue 4 on the song, it creates cue 4 at the current time.
It only happens after it reaches the cue with the action set. Playing the song before, I can happily press cues to jump between them all.
My question is: Is this a bug? Or should I be putting something else in the "Action" field to jump to another cue point?
V8.2 b3967, also happened with previous build.
geposted Sat 18 Nov 17 @ 8:56 pm
Wickedmix sorted me out. using goto_cue (number) works a treat and everything as it should be now. Cheers Wicked :)
geposted Sat 18 Nov 17 @ 9:43 pm
