Topic: Automix and autoGain
prezPRO InfinityMember since 2005
I have recently noticed an issue with Automix... when Automix is engaged and playing through the populated list, I am noticing during the Automix (type have it set to smart) the volume of the next song will come in at a different volume level (I have my autoGain set to auto+remember). once the automix of the tracks completes the autoGain setting will apply (AFTER the mix) so I get either very loud or very quiet mixes then a drastic change after the automix.
has anyone else noticed this and/or experienced it? and how do I stop it?
it seems that the autoGain is not being applied to the next track until after the automix completes its current mix.
geposted Mon 20 Nov 17 @ 11:55 pm
set zerodb to -3 or -6 and autogain to auto ..... see if that helps
geposted Tue 21 Nov 17 @ 12:01 am
The remember setting uses any manual changes to the gain when the track has been previously played. If you want a perfect match then as above the correct setting is auto only.
geposted Tue 21 Nov 17 @ 7:43 am
