Topic: Vdj logo and album cover art.
lamozPRO InfinityMember since 2008
After years using vdj7 without any issues, I decided to upgrade my controller
to a Hercules jogvision. This meant I had to upgrade my vdj to 8. So I'll getting used
to both upgrades. Before it was easy to not display the album cover art on the browser. I can't figure out
how to remove this option now. Also the VDJ logo sits on top left corner, blocking the track info on deck 1
I do have the lifetime version and have found the settings so it does not display on the video window.
but cannot remove it on the skin. I'm using the karaoke scratch skin.
geposted Tue 21 Nov 17 @ 8:57 pm
I don't know what the lifetime version is, but if you have the Pro or controller version, you should register and log in so it shows that you are not a home user.
geposted Wed 22 Nov 17 @ 1:10 am
geposted Wed 22 Nov 17 @ 1:43 am
