Topic: Pc issues,
I have had issues with vdj 8, since I purchased it on my pc. First, every time I start the program, I have to sign in, even after checking the dont show again box. Next, none of my settings stay the same from my previous set. It is mildly frustrating to have to reset all of the things the way i want them every time I open the program! Once I get everything set up, it works awesome, and I absolutely love it! I also need to know how to limit the signal coming from the program to the controller! Someone help please!!!
geposted Tue 21 Nov 17 @ 10:00 pm
Maybe you are not allowed to save the settings file on your pc ?
Try run VDJ as admin
geposted Tue 21 Nov 17 @ 10:24 pm
Check you have 'write' permissions to your 'Documents>VirtualDJ folder'.
For more headroom on the audio go to settings and change the Gain to -6db then if to low set it to -3db.
geposted Tue 21 Nov 17 @ 10:34 pm
Also remember that if you open the software on a third machine, it will log you out of one of the other two. So you will have to log into one of the others. You should not log out of the software, just close it.
geposted Tue 21 Nov 17 @ 10:48 pm
