live feedback works fine when just using software when i use controller (MC6000mk2) it doesn't show up its ticked as on in settings
    geposted Sat 25 Nov 17 @ 8:55 am
          can anyone help me with this please
i've tried it on different computer the moment i use mc6000 mk2, live feedback disapears
geposted Wed 06 Dec 17 @ 9:53 am
          I have the same problem. Did you ever get an answer?
    geposted Sat 24 Feb 18 @ 4:03 pm
          no haven't got answer to problem yet :-(
    geposted Mon 12 Mar 18 @ 11:06 am
          I believe it is because the denon uses a hardware mixer to mix the sound.
So it is not possible for VDJ to know which deck is live and therefore not able to provide feedback.
geposted Mon 12 Mar 18 @ 11:26 am
          MC6000 Mk2 is software mix. Only the Mk1 has hardware control.
    geposted Mon 12 Mar 18 @ 11:28 am
          so it's genius dj or new controller :-(
    geposted Sun 22 Apr 18 @ 8:17 pm
          When your controller is connected, the volume faders and cross-fader on the screen are following your controller movement?
    geposted Mon 23 Apr 18 @ 6:32 am
          yes all works fine just no live feedback
    geposted Sat 05 May 18 @ 6:02 am
          Are you using a custom mapping for your controller. If so, do you still have it with factory default mapper?
    geposted Sat 05 May 18 @ 6:21 am
          using the factory mapping from disc that came with it
    geposted Fri 01 Jun 18 @ 8:55 pm
