Topic: NI X1mk2 Mapping Question
var '$fx1multi' ? var_equal '$fx1' 1 ? var '$shift' ? deck left effect 3 select +1 : deck left effect 3 active : var_equal '$fx1' 2 ? var '$shift' ? deck 2 effect 2 select +1 : deck 2 effect 2 active : var '$shift' ? deck left effect 3 select +1 : deck left effect 3 active : var_equal '$fx1' 1 ? var '$shift' ? deck 1 effect button 5 : deck 1 effect button 2 : var_equal '$fx1' 2 ? var '$shift' ? deck 2 effect button 5 : deck 2 effect button 2 : var '$shift' ? deck left effect button 5 : deck left pitch_reset 1% : var '$shift' ? deck left key_lock
Used the above mapping on the FX1_EFX3_ON button on a previous build. Everything worked fine. Once updated to b3994, the "deck left pitch_reset 1%" command no longer works. All other scripts on the mapping work in the update.
Any ideas?
geposted Tue 28 Nov 17 @ 8:34 am
