Topic: Crossfade slider working in wrong direction
jamesv1PRO InfinityMember since 2009
Hi
I use multideck crossfade on automix during dinner etc.
With my old, very basic controller, it worked fine.I bought a Denon MC7000 recently and the crossfader moves to the left for the right deck and to the right for the left deck.
Although this is not much of an issue it would be good to have it working correctly.
TIA for any advice
geposted Fri 01 Dec 17 @ 7:53 pm
check in your options
crossfaderHamster.
geposted Fri 01 Dec 17 @ 8:31 pm
Was set to no, changed it to yes. I'll see what happens over the next few tunes.
CrossfaderHamster, how are we meant to know what that is?
geposted Fri 01 Dec 17 @ 8:34 pm
It now tries to cross to correct side then jumps back again.
geposted Fri 01 Dec 17 @ 8:43 pm
That's kind of a general DJ term. Like crossfader or beatmixing
http://dj.rane.com/blog/history-of-the-hamster-switch
Are you sure your crossfader assigns are setup correctly?
It's the little A-Thru-B sliders just above the deck faders.
Often you set them up to handle the 2 main channels, so that deck 3 and deck 4 is thru (which bypass the crossfader), deck 1 is set to A and deck 2 is set to B, and then the CrossfaderHamster is set to no
geposted Fri 01 Dec 17 @ 8:51 pm
Yes these are working as expected
geposted Fri 01 Dec 17 @ 9:04 pm
Ok, but they only assign how the crossfader works, and the crossfader is reversed for some reason without being set to it,
So what makes you say that they work as expected?
geposted Fri 01 Dec 17 @ 9:07 pm
With either A or B selected the manual crossfader works as expected
geposted Fri 01 Dec 17 @ 9:22 pm
Super. So there there is no reverse problem when you setup when A or B is selected properly for the crossfader?
geposted Sat 02 Dec 17 @ 7:53 am
Yes the crossfader works perfectly when using manually.
geposted Sat 09 Dec 17 @ 9:28 pm
