Topic: Ask the DJ won't appears on my screen
jucenicPRO InfinityMember since 2012
Hello, Ask the DJ is gone from my screen, how I can get it back? Any solution? Thanks
geposted Sat 02 Dec 17 @ 7:03 am
Do you mean in the directory list on the left under "Lists and advice"?
If so you may have just accidentally hidden it
Try right-clicking "Lists and advice" and see if you can select to show it again
geposted Sat 02 Dec 17 @ 7:39 am
Thanks, I will try
geposted Tue 05 Dec 17 @ 5:56 am
If still not there (after doing what Klaus has suggested), then you may have moved it to a different root folder. In this case, click on the Browser Options button (small radio button above the A-/A+ buttons) and choose "Reset Root Folders"
geposted Tue 05 Dec 17 @ 8:53 am
