Hi
Not long had VIRTUAL DJ 8.2 and having problems getting headphone to work from the same sound card. i am using windows 10 with 3 out puts with one mic input, and have the home version of virtual DJ 8.2.
In windows it says that it has detected both out put on the master and headphones so not too sure if my laptop is having a bad day or is it due to its just the home version. if it is due to the home version then ill stop playing with it and run it as is
thanks
thanks
geposted Wed 06 Dec 17 @ 10:33 pm
mick mouse wrote :
Hi
thanks
thanks
If your laptop somehow has 2 separate soundcards you should be able to make it work by setting it up correctly in the audio settings
If not, you can use a stereo to mono splitter cable, and have master as and mono output and headphones as another mono output, and then set it up as "stereo to mono splitter" in audio settings
geposted Thu 07 Dec 17 @ 5:34 am
Hi thank for the info just a couple more questions and i may be able to resolve my problem
1, Is it possible to use one of the 3 output (from the 5.1 surround sound ) or would I need the two sound cards if not I may know the reason.
2, Dose virtual DJ pick up use the windows driver for the sound cards input and output and use these ?
again
thanks
again
thanks
geposted Thu 07 Dec 17 @ 6:21 pm
