I use 8.2. I have a folder of 900 songs, but I can't find a setting to play all of them one after another? I searched for a solutions, played around with the settings, but nothing works.
Also, if the problem is fixed, is there a way to remove the silences in real time while playing and make the next song fade in the one playing at the end?
Thank you!
Thank you!
geposted Mon 11 Dec 17 @ 12:20 pm
Thank you!
Thank you!
Yes, you probably need the automix function
Take a look at this video:
geposted Mon 11 Dec 17 @ 12:43 pm
