Topic: Need Help mapping crossfader autostart but not volume fader autostart
Using original wego. any help would be appreciated. Autostart in options does both volume and crossfader autostart of the track. Hoping to just autostart next track with crossfader, but not have it effected by volume slider
Thanks
Jason
geposted Mon 11 Dec 17 @ 10:50 pm
I am afraid the setting applies to both Crossfader and Volume faders, so the only way at the moment is custom mapping.
Crossfader Start. Map the crossfader as :
crossfader & param_equal 0% ? set '$leftreach' 1 : param_equal 100% ? set '$rightreach' 1 : var '$leftreach' ? deck right play & set '$leftreach' 0 & set '$rightreach' 0 : var '$rightreach' ? deck left play & & set '$leftreach' 0 & set '$rightreach' 0 : & set '$leftreach' 0 & set '$rightreach' 0
Crossfader Start/Stop. Map the crossfader as :
crossfader & param_equal 0% ? set '$leftreach' 1 & deck right stop : param_equal 100% ? set '$rightreach' 1 & deck left stop : var '$leftreach' ? deck right play & set '$leftreach' 0 & set '$rightreach' 0 : var '$rightreach' ? deck left play & & set '$leftreach' 0 & set '$rightreach' 0 : & set '$leftreach' 0 & set '$rightreach' 0
Crossfader Start/Stop with on/off:
Map a Button to turn on/off :
toggle '$cfstart'
Map the Crossfader as :
crossfader & var '$cfstart' ? param_equal 0% ? set '$leftreach' 1 & deck right stop : param_equal 100% ? set '$rightreach' 1 & deck left stop : var '$leftreach' ? deck right play & set '$leftreach' 0 & set '$rightreach' 0 : var '$rightreach' ? deck left play & & set '$leftreach' 0 & set '$rightreach' 0 : & set '$leftreach' 0 & set '$rightreach' 0 : nothing
geposted Tue 12 Dec 17 @ 12:29 pm
