Topic: Platinum Notes
Hey, has anyone used Mixed in Key's, "Platinum Notes", software?
If so, is it good?
For that matter what about "Mashups 2"?
geposted Tue 12 Dec 17 @ 8:37 am
I´m using mik and platinum notes.
Really like the way I can make my own settings in _pn, like output volume or compression etc.
It´s perfect that all my files (.mp3) have the same volume and its easy to change templates. (I would love a version that fixes .mp4 with same functions :(
MIK is used as a keymaker for my files (both .mp3 & .mp4) and it´s saved as comments, I mostly use it to compare the keys with vdjs own analyze.
If you use other programs or hardware it´s good, but you really dont need it for vdj use.
I know it but I don't use it, as the things it does are all possible in standard audio editing software (I use Adobe Audition).
It's a quick fix I guess, for anyone that finds Audition etc. too complex, but I'd rather have a bit more control over what's happening to my audio.
