Forum: Addons
Topic: Party Sampler
geposted Tue 12 Dec 17 @ 10:36 am
These add-ons don't seem to work for vdj8
Works fine here
Same problem here. Samples don't work (VDJ 7.0.3).
When I try to load the .vdjsample file in the samples section it remains empty at the bottom.
Any tips?
worked in 8.2
Any tips?
It's in the v8 section, so I don't think it's supposed to work with v7
If you want to keep on using v7, you can go to the legacy part of the page for plugins/samples:
http://www.virtualdj.com/addons/skins.html
Guys, I Created This Sample Pack In VDJ 8.2 Build 3573 And It Will Not Work In Older Versions. You Should Update Your VDJ Software.
