Discussions about VirtualDJ, and about DJing in general
Forum Guidelines
If you need extended support, contact our Support Team.
(*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Sandbox and Reloop Mixtour
Dear all,
It seems that sandbox is unavailable even with my mouse while using VDJ 8.2 with the Reloop Mixtour controller...is it normal?
Thanks and have a good weekend,
Jeff
Posted Fri 15 Dec 17 @ 5:05 pm
I think sandbox only works when you are running in 2 deck mode.
Posted Fri 15 Dec 17 @ 5:51 pm
Thanks, but I am actually running it in a to decks mode.
Cheers
Posted Mon 18 Dec 17 @ 9:16 am
knjk
Posted Mon 18 Dec 17 @ 5:07 pm
Sandbox should be available if you're using the unit's default Audio Setup (Master & Headphones)
If you're using a different audio setup (with another soundcard maybe) then Sandbox may not be available
Posted Mon 18 Dec 17 @ 6:51 pm
Posted Mon 18 Dec 17 @ 10:55 pm
