I am running VDJ8.2 with a Adj VMS5.0 controller, when I try to listen to a song via the plf button nothing comes through the headphones but I can use pre-listen. This is ok for most jobs but no good for mixing as I need to listen to other decks at the same time for the right que plasses.
geposted Fri 15 Dec 17 @ 8:27 pm
follow this guide to get the audio set up properly https://www.virtualdj.com/manuals/hardware/americanaudio/vms5/installation.html
might want read through the rest as well :-)
geposted Fri 15 Dec 17 @ 9:17 pm
