Just updated to 4032 and notice that my history no longer appears under lists & advice.
geposted Tue 19 Dec 17 @ 6:44 pm
Are your History files/folders still at /Documents/VirtualDJ/History folder ?
Any chance you have hidden or moved History ? If so, right-click on the List & Devices folder in VirtualDJ and see if there is an option to "Show History"
geposted Tue 19 Dec 17 @ 9:22 pm
Yes history in folder. Clicked on show history and it is back.
I did not change any settings or delete this, but all is okay now.
Thanks
Thanks
geposted Wed 20 Dec 17 @ 3:25 pm
Installed 4032, was mixing at home (fortunately) into the 10th song or so, hit play button on controller (CUE was on, volumes down) and something happened don't know what but, display flashed, switched from 4 to 2 track mode, all of sudden the finder was frontmost. Oh and after a while I noticed recording had stopped. Continued mixing and after a few more songs, tracks waveforms froze, music kept playing though.
With some of the previous beta builds I was also getting track display freezes and sometimes odd behaviour.
VDJ always used to be very very stable.
MacBook Pro 3.1 Ghz i7, 16GB Ram, 500GB SSD 10.12.6
(This machine barely raises a bar in the CPU meter) Controller NI S4 MKII
geposted Thu 28 Dec 17 @ 11:41 pm
