Topic: Change language of VDJ 8.2 OEM
geposted Fri 22 Dec 17 @ 7:09 pm
Not sure why the link is dead. I have posted my English language file below:
[DELETED]
Copy it to Documents> VirtuaDJ> Languages (it may be there already?)
Start VDJ, go to options, search for language then select it in the click down menu.
geposted Fri 22 Dec 17 @ 7:28 pm
The URL using /addons/ is for the old (now removed from the download menu) VDJ 7 and earlier downloads.
Besides, the only English file available from the old downloads area is for VDJ 5.
There's no English file in the VDJ 8 downloads presumably because it comes as standard with the VDJ installation available to all from the download link at the top of the site.
geposted Fri 22 Dec 17 @ 7:48 pm
@kradcliffe Tnx, i see there was no need to install a language file, because the option you mentioned already had several languages.
geposted Fri 22 Dec 17 @ 7:57 pm
