Hallo, ich nutze Virtual DJ 8.2 zusammen mit Denon MCX 8000 und mich würde interessieren ob es
die Möglichkeit gibt eine End of Track Warnung zu aktivieren, so das z.b. in den Letzten 15 Sekunden des Tracks der LED Kranz am MCX anfängt zu blinken?
Besitzt VDJ diese Funktion?
Gruß !David
Gruß !David
geposted Mon 25 Dec 17 @ 8:47 am
          Hi David, ja aber "kann" Probleme bereiten.
Musst folgendes mappen: LED_JOG_ALL "songpos_remain 15000ms ? blink : on"
djdad wrote :
For the blinking LEDs. The initial mapping files had those to blink when track was reaching near its end, but we removed this as it was creating some minor issues.
You can try it yourself..
map the LED_JOG_ALL key as.
songpos_remain 30000ms ? blink : on
and leave the LED_JOG as ..
get_rotation
The LED_JOG_ALL is the issue actually. What it does is to turn all Leds on and at the same time "enable" the LEDs. But if you send ON, and no rotation after that (e.g. track ends and stops at its beginning/load position), you may end up with all LEds on.
The best approach would be the firmware to provide a way to control and change the pattern (which at the moment is only accessed via the unit settings). If such a way existed, we could blink between the 2 patterns without using the LED_JOG_ALL key. I had emailed Denon, but you know, when the bundled software doesnt give you mapping possibilities and the "bug" is not there (they dont blink the Jog Leds either), then firmware updates are hard to happen ;)
Grüße Tom
get_rotation
Grüße Tom
geposted Mon 25 Dec 17 @ 9:23 am
          Ist standardmäßig bei der LED Load gemappt; Grund dafür hat Tom oben zitiert.
    geposted Mon 25 Dec 17 @ 10:01 am
          Ok Danke, bei mir funktionierst bis jetzt ohne Probleme.
    geposted Mon 25 Dec 17 @ 3:42 pm
