hello. I have been running virtual dj 7 on a pc with windows 7, but now I have just bought a new MacBook pro and downloaded virtual dj 8.
I pay for a subscription to unlimited content and I'm wondering what is the best way for me to get all of my netsearch "saved to cache" song library, cue points, virtual playlists, etc transferred over from my existing pc with virtual dj 7 TO this new MacBook pro with virtual dj 8.
I have read and read and read on here and on other sites and I'm more confused now than I was to begin with. thanks for any help ! Eric
geposted Thu 28 Dec 17 @ 7:30 pm
is there anyone here that could point me in the right direction on this ?
I spent all day yesterday researching this in addition to other days that I've spent many many hours with no solution found. I would imagine that this may be a stupid question for some of you here, but I can't seem to find an answer and I am trying to keep from searching for and loading thousands of saved cache files. I wouldn't even be attempting to change from pc to MacBook pro, but I keep having more and more glitches with both of my pc's, so I am changing over to a more stable / less glitchy MacBook pro. thanks !
geposted Fri 29 Dec 17 @ 2:42 pm
Did you not check the wiki?
This should get you started https://www.virtualdj.com/wiki/PC%20Transfer%20To%20Mac.html
OK it's for VDJ 7 but the basics still apply.
You could also click here.
geposted Fri 29 Dec 17 @ 4:57 pm
thank you ! I will look into all of that
geposted Fri 29 Dec 17 @ 7:54 pm
