I have a base unit operating that will remotely send all signal to wireless mixer
buttons on the neck
tuning pegs for twist nobs
fret markings for pressure buttons
saddle buttons
scratch plate well scratch plate
and sound hole double disks
I just need a little help with placement of buttons relative to placement practicality
buttons on the neck
saddle buttons
geposted Tue 02 Jan 18 @ 12:18 am
truth is you can more then likely mod a guitar hero guitar in a hour.. as long as its the usb one.. the computer sees it a a hid and then gives me a code. then we build from there.
im just not sure as a home user you can use a controller with out upgrading.
geposted Thu 11 Jan 18 @ 2:32 am
