Forum: VirtualDJ 8.2 Technical Support
Use this forum to report any bug, questions or comment related to the latest version of VirtualDJ 8.2.
Forum Guidelines
(NOTE: VirtualDJ 8.2 is continuously updated, so many older topic on this forum are most probably already fixed in the current build)
Topic: Problem with Stanton scs.1D and 8.2
Hello, Ive got a Stanton SCS.1D which worked with no issues until the first 8.2 build. If I go back to the 8.0 build it works fine but on any 8.2 build after about an hour worth of djing, when I access the playing track using the motorised platter it jumps through the track (skipping or moving right to the end, you cannot stop or drag the track in vinyl mode and if you to many times to causes VDJ8 to crash
geposted Wed 03 Jan 18 @ 4:21 pm
