For reporting any bug, questions or comment related to the latest version of VirtualDJ
(NOTE: VirtualDJ continuously updated, so many older topic on this forum are most probably already fixed in the current build)
If you need extended support, contact our Support Team.
Forum Guidelines  (*) The moderators hold the rights to move or modify posts in order to keep the discussions clear or to facilitate the search.
Topic: Interfaces made for Version 8
diramiPRO InfinityMember since 2011
Hello,
How can I set the default skin on my phone (VirtualDJ Remote)? What's his name? Thanks.
geposted Wed 03 Jan 18 @ 5:18 pm
Skins for the remote are written differently, so you can't just use a normal VDJ skin on the remote.
geposted Wed 03 Jan 18 @ 5:37 pm
I have mistakenly put another skin in my settings and I can not get it back now. I do not know how to do it?
geposted Wed 03 Jan 18 @ 5:51 pm
geposted Wed 03 Jan 18 @ 5:56 pm
OK. Thank you very much. It's a bit different skin but it works. :-)
geposted Wed 03 Jan 18 @ 6:36 pm
