Saw a feature i liked in a software whos name i wont mention, but i was wondering if it can be made to work in VJD. I have my songs color coded and would like the platter background to change color to match what i have the song color set to. Is there a way for the skin to read the browser color ??
geposted Wed 03 Jan 18 @ 6:19 pm
Yes, it is possible for a skin to use the color. But it's up to the developer to implement such a feature.
The default skin does not does what you mention.
geposted Sat 06 Jan 18 @ 9:14 am
I am using a skin which i have modified, but i have no idea how i would go about coding that in the xml. Do you have any ideas what lines i can add or how i would go about it?
Thanks
Thanks
geposted Mon 08 Jan 18 @ 8:44 pm
geposted Mon 08 Jan 18 @ 8:54 pm
