Topic: Push/Hold to Play Cue
Is there a way to set a pad to play a cue when either the cue pad button itself is held, or when the play button is held.
Say I have cue 1, I want to only play cue 1 when either a pad is being "held" pressed, or when the play/pause button is "held" pressed.
geposted Sat 13 Jan 18 @ 2:23 pm
I believe what you want can be done if the hotcueMode is set to "Stutter" from VDJ Settings. When set that way, hotcues will play while the Pad/button is pressed and and stop when released or continue playing if before releasing the Pad PLAY is pressed.
geposted Sat 13 Jan 18 @ 2:42 pm
Just found something on pg 16 of the user guide, but setting these settings don't seem to have any noticeable effect, the play button still plays continuously even after depressed.
geposted Sat 13 Jan 18 @ 3:19 pm
geposted Sat 13 Jan 18 @ 3:20 pm
Simply holding down cue when cued, will play while pressed on most controllers
geposted Sat 13 Jan 18 @ 3:26 pm
not on the reloop touch
geposted Sat 13 Jan 18 @ 3:50 pm
I think I figured it out.
Load Cue
Hit Play/Pause Once to start playing
Hit Play/Pause Once to pause playing
Press and Hold Start/Cue to play
geposted Sun 21 Jan 18 @ 12:39 am
