Topic: Second hand Hercules RMX question
Hi I just got a used Hercules RMX with no software. The question is if I pay for the pro license ($99) would I then be able to use it even though I don’t have the software or serial number?
Thanks in advanced
geposted Wed 17 Jan 18 @ 3:24 am
You can buy a RMX license, and you would be good to go. The RMX license is $99.00, and will give you full access to that controller. You will only be able to use that controller. Make sure that you list the right controller, because there is an RMX2 license also.
geposted Wed 17 Jan 18 @ 3:30 am
Thanks
geposted Wed 17 Jan 18 @ 4:05 am
The $99 license is not the Pro license. It's a Plus license, for home use only.
The Pro license is $299.
geposted Wed 17 Jan 18 @ 6:10 pm
Thanks in advanced
Download the drivers from Hercules to work with VDJ
geposted Wed 31 Jan 18 @ 8:03 pm
