Hello there,
Strange thing started after few songs of play the system starts to sound like Distortion and it get worse.
I have the following Mac book pro, Virtual DJ, denon MC 7000, bose l1 model 2 with bose tone match mixer. I did try to listen to songs on headphones directly connected to MacBook Pro while it was playing on Virtual DJ it sounded fine I didn’t listen to lots of songs and it could have sounded distortion. I turned off then turned on the entire system then turned back on and it sound alright for few songs and then again it sounds distortion and gradually getting worse.
Not sure what’s going on any ideas will greatly be appreciated.
Thankyou so very much for all your guidance.
Faisal
Faisal
geposted Wed 17 Jan 18 @ 6:51 am
Try to increase the latency either from the Denon Control panel Utility if you are using Denon ASIO (in Windows) drivers or from the latency setting from VirtualDJ Settings if you are using WASAPI (Windows) or CoreAudio (Mac) drivers
If by increasing the latency helps at any way, then you should optimize your computer for best realtime performance if you want to go with low latency.
Windows : http://www.virtualdj.com/wiki/PC%20Optimize.html
Mac : http://www.virtualdj.com/wiki/Mac%20Optimize.html
geposted Wed 17 Jan 18 @ 7:14 am
Denon have just released new firmware to correct distortion on the MC7000 with MacOS
geposted Wed 17 Jan 18 @ 9:49 am
