I have videoCrossfaderAuto selected which works well in 2 deck mode, however I have noticed when looping and mixing in a new track the transition starts when the incoming track fader is around the 30% mark.
If I have a loop running in the background depending on volume it brings in the new video instead of leaving the old one until I have completed the mix.
Is there a way of setting the incoming fader level before the transition cuts in?
geposted Fri 19 Jan 18 @ 2:56 pm
Anything on this one?
Adion?
Adion?
geposted Wed 24 Jan 18 @ 1:55 pm
There's currently no way to adjust this level.
It depends on the selected transition if it will transition instantly at that point, or if it stops halfway and only completely moves to the next track after moving completely to the next track.
geposted Wed 24 Jan 18 @ 2:59 pm
OK, thanks. I will check out some of the transitions to see what's best.
geposted Wed 24 Jan 18 @ 3:19 pm
Keith - not sure if this will help in what you are trying to accomplish.
http://www.virtualdj.com/plugins/index.html?category=effects&search=autovideotransition
geposted Wed 24 Jan 18 @ 3:28 pm
Cheers Dan, I have installed it but can't figure out how to activate or configure it.
Edit, copied the .DLL to video transitions but it still doesn't appear to do anything.
geposted Wed 24 Jan 18 @ 3:39 pm
It will appear under master effect > autostart.
Thats where you access the settings.
I use this all the time as the transition only starts the crossfader hits 100% or 0%.
geposted Wed 24 Jan 18 @ 5:51 pm
Can you please explain how you have it configured, and do you need to have the normal auto video crossfader enabled?
Thanks.
Thanks.
geposted Wed 24 Jan 18 @ 6:57 pm
No, disable the standard auto crossfader.
geposted Wed 24 Jan 18 @ 9:11 pm
Thanks Dan, will give it a go at my gig later tonight.
geposted Wed 24 Jan 18 @ 9:17 pm
