Topic: Problem with Sampler
I just bought a new computer to run my Virtual DJ I downloaded my license to my new computer. But now everytime I use my different Sampler's the sound only comes from my computer speakers.......not my other speakers........everything else works good except the Sampler's....
geposted Sat 20 Jan 18 @ 1:47 pm
Configurations, options, sampleOutputDeck, set to 0 for sample to come out of master.
geposted Sat 20 Jan 18 @ 10:55 pm
Ok I went to check what you said .....it was already a 0.....
geposted Sun 21 Jan 18 @ 1:50 pm
Unless you have a "sampler" line in your Audio Setup in VirtualDJ , sampler should go to whatever sound card / channel you have for the "Master" line.
By default, Sampler will go through Headphones as well. You can mute Sampler from Headphones with the setting SamplerHeadphones to No
A screenshot of your Audio Setup would help as well.
geposted Sun 21 Jan 18 @ 3:38 pm
ok problem solved thanks
geposted Mon 22 Jan 18 @ 8:49 pm
How, let others know that may experience the same issue.
geposted Mon 22 Jan 18 @ 11:50 pm
