Could someone possibly show a screenshot of configurations to pre fade listen? Every time I try it I end up with the channels 1 & 2 audios playing sound even when the faders are fully down. Just bought the denon MC6000MKII. Thank you.
geposted Fri 26 Jan 18 @ 11:55 am
The simplest is probably if you set it up like it is shown in the VDJ hardware manual for it:
The step-by-step guide for the setup is here:
http://www.virtualdj.com/manuals/hardware/denon/mc6000mkii/installation.html
geposted Fri 26 Jan 18 @ 12:01 pm
Thank you, but the only options it's giving me are these three
geposted Sat 27 Jan 18 @ 7:42 pm
ASIO Drivers need to be installed if you would like to use them see manual above for links.
geposted Sat 27 Jan 18 @ 8:08 pm
Ah, okay, Thanks.
geposted Sat 27 Jan 18 @ 8:17 pm
