Topic: VDJ Remote (Android) Cannot display rhythmzone waveform
Running the latest version of the VDJ Remote app (just bought it today) and have tried multiple skins (including my own), and am seeing a consistent problem.
If a skin uses rhythmzone to display a waveform, I'll be able to see the beatmarkers and cue points, but not the waveform.
If it uses a scratchwave then it displays fine, unfortunately I prefer the rhythmzone style wave.
Is this something that's likely to be fixed.
Also, is there a way to change the colour of the little triangle for rhythmzone cue points. The dark blue is very difficult to see.
geposted Tue 30 Jan 18 @ 1:39 am
What brand/model is your device and what Android version is it running ?
OnePlus 5T running Oreo 8.0
Is it the official update of OxygenOS? Oreo is only beeing rolled out since yesterday I believe.
I'm owning a OnePlus too, but with a custom rom of oreo. If it is of any help I can check if the same is happening on my device as well this evening.
It's official OxygenOS Oreo, yes, not Cyanogen or anything.
OnePlus 5T A5010, Operating System: OxygenOS based on Android 7.1.1 Nougat,
OS details.
Stock phone skin using rhythmzone
My modded skin, using scratchwave, but I want to use rhythmzone.
Official Oreo update, but beware that it's a one-way update, needing a full wipe to go back to Nougat: http://otafsg.h2os.com/patch/amazone2/GLO/OnePlus5TOxygen/OnePlus5TOxygen_43.O.28_GLO_028_1801281939/OnePlus5TOxygen_43_OTA_028_all_1801281939_bd7a6aa0ae9d74c.zip
Edit: Gonna try it on my old Oppo R9S, because I don't use it any more and hey, maybe I can make a dedicated screen for my MixTrack 3 :)
Edit2: Exact same fault on the R9S, running LineageOS Nougat.
Bump? Anyone got a fix for this? Alternatively can I get a refund on the app please?
