Hi all,
This thread says you can't go more than -5 seconds before the beginning of a track.
https://www.virtualdj.com/forums/208146/VirtualDJ_8_1_Technical_Support/reverse_issue.html
I'd like to put a cue point 8 bars before the beginning of the track, which ends up being -7 or -8 seconds, but I can't get there because I can't go past -5 seconds. Is there any way to do this in Virtual DJ? Thanks!
geposted Tue 30 Jan 18 @ 5:07 am
No, there is no way to do that.
As stated by Adion in that topic, it was designed like that for a reason. So, unless you give us a good reason why you would want to go that far back in the track, it will not be changed
geposted Tue 30 Jan 18 @ 6:18 am
When I made a video using goto to do "prepared beat jump mixing", where you do the mix, and then jump back maybe 16 bars to let VDJ automatically redo the mix 16 bars in the future, I think I hit the limit at one point. So I guess that could be a usecase
geposted Tue 30 Jan 18 @ 8:54 am
So that was a "demonstration" case, or is there a real-life scenario where this could be used ? If e.g. you have a button that jumps 64 beats backwards, to help you with some "live" remixing, if VDJ allows to go back that much (beyond the track's start), you will get no music , in fact it protects you from that and the button wont do anything.... or do i miss something ??
geposted Tue 30 Jan 18 @ 10:47 am
For me it was a demo. I don't think I've ever used this mixing technique live
I was just trying to help come up with a use case. Sorry :)
geposted Tue 30 Jan 18 @ 12:01 pm
Could this be done with a POI and maybe a cue point
Put the POI at the beginning of the track, so it says "wait for x amount of time (or x bars) then play" or "...then got to hotcue #1" (etc)
geposted Tue 30 Jan 18 @ 6:29 pm
