Anyone ever have this problem? I'm not exactly sure how to solve it.
It's not that it skips. Skipping is something different. It HANGS. like a hiccup. Like it just stops and half a second later, continues.
It seems like it happens less when I turn off WIFI, but that could be in my head, as it HAS still happened. It should be noted that this happens when I use my S4 in Traktor too.
What could be the problem and how would I fix this? Any settings in VDJ to curb this? I feel like I recall a setting in Traktor that fixed this....
geposted Tue 30 Jan 18 @ 8:29 pm
It's usually because your laptop is doing something else and locking/blocking resources
The wifi driver is a "usual suspect" but there are more than one
This doc may help you:
https://www.facebook.com/notes/virtual-dj-official-group/digital-djing-optimisation-guide-win-10-fix-vdj-7-vdj-8-serato-traktor/10152868466644202/
geposted Tue 30 Jan 18 @ 11:17 pm
maybe a bad usb cable?
geposted Wed 31 Jan 18 @ 12:28 am
You can use Latencymon to see if a driver is using execution time
http://www.resplendence.com/latencymon
geposted Wed 31 Jan 18 @ 8:52 am
