Topic: KEY CODE
koskokControlleristMember since 2017
Για σας,νεος στο φορουμ,αγορασα μια αδεια home plus,οταν παω να ξεκινησω τον κοντρολερ μου ζηταει key code.Που θα το δω.Ευχαριστω και ζηταω συγνωμη για την ασχετοσυνη μου
geposted Wed 31 Jan 18 @ 10:36 am
Are you sure you are using v8 of VDJ?
It has no key code. You instead use the same credentials as on this forum. The login page in VDJ should look like this:
geposted Wed 31 Jan 18 @ 12:10 pm
grobik0Home userMember since 2016
geposted Fri 02 Feb 18 @ 12:24 am
pseftPRO InfinityMember since 2009
LEVENDI, this link is for greeks
https://www.virtualdj.com/forums/7/Greek_Forum.html
geposted Fri 20 Apr 18 @ 9:07 am
is there a keycode for 8.2
geposted Tue 19 Jun 18 @ 9:51 pm
No. Its server side authentication only.
geposted Tue 19 Jun 18 @ 10:03 pm
I need the edition code for VJD v8 please?
geposted Fri 03 Aug 18 @ 12:55 pm
Read the messages above yours...
geposted Fri 03 Aug 18 @ 4:36 pm
