I'm having trouble trying to figure out how in the hell you can cue up the songs in the earphones. For example, both songs are playing out the master volume through the speakers. I moved the crossfader to the left and hear the music in the earphones, but I don't hear nothing coming from the right channel in the earphones when I'm trying to mix and cue up the songs. I pressed both cue buttons on virtual dj but still can't hear the mix before it comes out on the loud speakers. Actually it does that when I move the crossfader to the left or right. All I want to do is here my cues beforehand in the earphones. Can someone help me out with this???
geposted Thu 01 Feb 18 @ 9:16 pm
post a screeen capture of you audio config
geposted Thu 01 Feb 18 @ 9:48 pm
I can't seem to upload the pic on here. But any advice is welcome
geposted Fri 02 Feb 18 @ 4:28 pm
Make sure everything is set the way this manual shows you
https://www.virtualdj.com/manuals/hardware/pioneer/ddjsr2/setup.html
geposted Fri 02 Feb 18 @ 5:50 pm
Thanks. Shouldn't the headphones be set as output 1 and 2?? Also how come I have to keep changing the audio settings after I apply them? When I exit vjd and log back in, the settings are not saved and have to go through the whole process again. I know it's a settings thing but damn I didn't have this much trouble with the numark
geposted Mon 05 Feb 18 @ 7:45 pm
have you tried saving the config ... use the disk icon bottom right corner see image below
you can also give it a name type in the box where you see DDJERGO next to the disk icon in the image
if you need to recall a saved config select it it the drop down box where you typed the name and hit apply.
PS all of the stuff is in the manual see -> https://www.virtualdj.com/manuals/virtualdj8/settings/audiosetup.html
geposted Mon 05 Feb 18 @ 8:18 pm
Ok bet. Thanks
geposted Mon 05 Feb 18 @ 9:22 pm
