I need a script to map to a tab/pad on the SR2, for video transition to deck A. If pressed again, it stops the transition. When pressed again, it continues to deck A. I need the same for B, but assume I would just have to change letters. My transitions are not always the same, sometimes I transition the video before the audio. I also like to stop the transition, and hold it for the effect. Any help would be appreciated.
geposted Sun 04 Feb 18 @ 11:46 am
action_deck 1 ? video_transition "left" : video_transition "right"
I think that should do it, not at my machine to test.
geposted Sun 04 Feb 18 @ 9:06 pm
That works perfect, thank you very much.
geposted Sun 04 Feb 18 @ 10:27 pm
Ney worries, I've got a beat timed transition/v xf thing I need to work on, I'll pm you a beta once I can get it going.
geposted Mon 05 Feb 18 @ 7:19 pm
