Topic: Automix on Deck 2
I want to have Deck 1 for karaoke songs on one audio channel and use Deck 2 for automix (BGM) on another audio channel that would run continuously (the automix feature in karaoke still needs work). Is there a way to set Automix to play on Deck 2 instead of Deck 1? I've been reading, and it says it only plays on the Master channel.
geposted Tue 06 Feb 18 @ 4:29 pm
djdonnPRO InfinityMember since 2006
Are you only using 1 sound card? You may need to use 2?
geposted Tue 06 Feb 18 @ 5:37 pm
I figured it it out. I was clicking incorrectly on the MD button for deck 2. :)
geposted Tue 06 Feb 18 @ 5:51 pm
