Hi All. Just wondering if anyone can help please? I'm thinking of loading Freestyler on the same machine as VDJ and searching the forum it looks like this has been done many times. I'm wondering though if anyone has had experience of it causing conflicts with the music playback? VDJ for me has been rock solid but I don't want to mess that up by getting carried away. Ideally I'm looking to continue running my MC6000mk2 and also add a midi pad for some control of freestyler. The system it will be run on is an Lenovo T430 (optimised for DJ use), SSD, 4.0GB RAM, i53360M 2.8GHz and Windows 7 Pro 64 Bit.
Thanks in advance.
Thanks in advance.
geposted Tue 13 Feb 18 @ 5:07 am
You shouldn't have issues, but if I was you I would certainly consider to upgrade my RAM to 8GB so that there's plenty of memory for all applications.
geposted Tue 13 Feb 18 @ 5:08 pm
Phantom, thanks for the advice. Much appreciated.
geposted Tue 13 Feb 18 @ 8:26 pm
