Topic: VDJ FILTER
Can we adjust the resonance of the standard filter, like the FX bank filter, other than subtle and strong in the settings? I'd like it inbetween. If not, how about in a future update.
Sometimes a slight turn from the center gives a strange effect, not quite as expected. I can't explain it yet but the lad i DJ with noticed it too, when it happened to him, after I'd spent ages failing to explain it. I'm using a Denon MC7000. Any insight appreciated.
geposted Tue 13 Feb 18 @ 8:15 pm
You can add a factor to it to lessen it's impact. Like in this script:
param_multiply 0.22 & param_add 0.4 & filter
You can of course change the values
You can also completely replace it like explained in this video:
geposted Wed 14 Feb 18 @ 6:25 am
This is a guess but have you tried typing in a numerical into the setting?, further guess it should be between 0 and 1.0
geposted Wed 14 Feb 18 @ 11:00 am
Thank you. I'll give those a try.
geposted Wed 14 Feb 18 @ 1:04 pm
Yes, this works.
Setting the filter knob at 9 o'clock and going through 0.1, 0.2, 0.3... in the settings and a difference can be heard. I've gone for 0.8, possibly drop it to 0.7.
klausmogensen wrote :
You can of course
In your video you show the on/off parameter as % variable near to 12, how the VDJ default skin handles the filter knob on/off, could this be similar to the strange behaviour i sometimes experience mentioned in my OP. As using a controller with an indent at 12, could I go into the default skin and set this to an exact?
I really appreciate your comments, many thanks.
geposted Wed 14 Feb 18 @ 3:50 pm
