Topic: any way for virtual dj to handle songs with two BPMs ?
just wondering, sometimes we get songs that start out at about 130 bpm and then changes halfway through to about 95 bpm...particularly wity some contemporary brazilian music
is there any way for virtual dj to handle this so that the sync and looping can be used at either section? if not, it would be an awesome feature for the future
geposted Wed 14 Feb 18 @ 12:20 pm
Use action poi to call the 'set_bpm' script
im a bit confused that doesnt seem to do anything, once i put in "set BPM, do i have to then type afterward the BPM i want to set it to?
i realised the BPM editor also has multiple BPM option ,but after activating it, again doesnt seem like anything has changed
You can handle it with the BPM Editor, but you have to do it manually on your own. Maybe there is an tutorial on YouTube, just found one in german language which explains Variable BPM.
Matty1000 wrote :
nice , yeah i got it now
this guy explains it at the very end of this 18 minute video https://www.youtube.com/watch?v=tG3FeNh5oos
That link is how to make a dj drop.
In the bpm editor, if you click on the dot at the bottom to the right of the bpm number, you can use Re-analyze (multiple BPM) and it will set different bpms for each different bpm it detects.
It sounds like a great idea, but it doesn't work very well. I tested it back when it was first added, and found it almost useless.
I just tried again now (with the same test track) and it's not been improved. If it was made more usable it would be a really useful feature.
I've just used it and it worked quite well.
Re-analyze multiple bpm. Go to the point where the bpm changes and add an anchor. Zoom in to get it precise. Set the anchor to 1 of 4. It wasn't working well for me until i realised what the 1 of 4 tick box was for.
The track i did was the Macklemore bootleg that transitions from 128 bpm to 96, via Calabria Sax changing into the melody of Thrift Shop.
It would be useful if there was a live BPM option.
Currently I just make sure to ignore the BPM reading and avoid using things that depend on the beatgrid like loops and FX.
I've asked for that so many times now it's unbelievable.
The way it is now works great for me. Granted its used for mostly transition tracks but it does work.
For a transition track (like 90bpm to 110bpm) I find the multi-bpm feature to work quite well
I made a quick example video, where I do a regular re-analyze, then a multi-bpm re-analyze, and the play the track showing the BPM changes
For a warp like feature it doesn't work
That will take.... a warp like feature, I guess, which creates a new audio file in advance :)
I fully appreciate your videos Klausmogensen but the Multi BPM one is wrong. Your grid hasn't aligned correctly. The 1st beat of the bar, down beat is off. It's easily corrected using the 1 of 4 tick box and placing that anchor at the 1st beat of the bpm switch. Zoom in to get it precise.
If the BPM goes out simply nudge it .5 and we can visually see the grid move closer or further. If further, adjust the other way.
This is very easy and works well, thank you VDJ.
True. As you explain that is step 2 :)
