Topic: Scripting question
I am mapping my Numark Dj2go2. Trying to alternate my channel level knobs between level and gain while pressing shift. The way I want it to work is the knob is set for level by default, and gain when shift is pressed. The script is have is:
GAIN
volume & variables '$hift'? gain : level : nothing
The problem I'm having is that with shift pressed, both the gain AND level controls are affected at the same time. Meaning they both go up/down together. How do I separate the two so that only the gain is affected while pressing shift?
Having the same problem with my cue level knob. I want the shift to control cue mix. I have it scripted like this:
HEADPHONES_VOLUME
headphone_volume & var '$hift'? headphone_mix : headphonevolume
Same thing happens here, both parameters move when shift is pressed.
Any help would be greatly appreciated!
geposted Thu 15 Feb 18 @ 9:28 pm
I forgot to add:
I am running Windows 10 on a Sony Vaio
And changed the SYNC buttons to SHIFT
geposted Thu 15 Feb 18 @ 9:33 pm
GAIN
var '$hift' ? gain : level : nothing
HEADPHONES_VOLUME
var '$hift' ? headphone_mix : headphone_volume
These should work, look at yours, look at mine and consider why you got the results you did.
Script does what you ask, and you asked,
control level and then if shift is pressed control gain, if shift isn't pressed control level.
geposted Thu 15 Feb 18 @ 9:45 pm
Awesome! That worked! I understand why now. I'm new to scripting. Your explanation makes sense!
Thank you for your help!
geposted Thu 15 Feb 18 @ 10:19 pm
No worries, I'll usually help if folk take a stab at script.
geposted Thu 15 Feb 18 @ 11:29 pm
locodog wrote :
GAIN
I believe the last " : nothing" is never reached and can be omitted. It's doing nothing anyway.
geposted Fri 16 Feb 18 @ 8:15 am
Correct, I just copy pasted.
geposted Sat 17 Feb 18 @ 8:00 am
