Forum: VirtualDJ Skins
Topic: VDJ 8 Default skin black color changes
Hi,
I'd like to know which lines i have to edit so i can change default vdj8 black color to any other, im aware that there might be lots of lines and it will include changing text color.
I'd like to go from black font color to something very smooth i can use during the day, like cyan or green.
Thank you !
geposted Mon 19 Feb 18 @ 1:21 am
The Font colors are indeed changed from the xml file of the skin zip file, but there is not any black font in the default skins.
If you need to change the background of something, then only Browser can be "coded". For all others, u need to edit the png file with some Application that can edit and handle transparent image files.
