Windows 10
VDJ V8.2 B4064
When renaming files, windows asks for administrator permission to change files, then windows gives an error saying "the source and destination filename are the same" so the files don't change.
But then VDJ can't find the files because it is looking for the new filenames.
How can I reverse/fix this? I renamed a whole album this way!
VDJ V8.2 B4064
geposted Sat 24 Feb 18 @ 9:04 pm
My guess is that you are changing the name in the "database" file, but because of the security setting in Windows, you're not actually changing the physical file name in Windows. I suspect you need to change your security setting in Windows so such changes aren't questioned by the system.
geposted Sat 24 Feb 18 @ 9:22 pm
Windows should ask for Administration privileges to rename files ONLY inside special folders (like the root of a drive, inside "Program Files" directory e.t.c.)
Where are your files located at ?
What type of user account are you using (is the user account an "Administrator" of this PC, or is it a simple user account)
What are the access rights (NTFS File permissions) on the directory you're trying to rename files ?
geposted Mon 26 Feb 18 @ 9:33 am
Because I changed username during a recent computer change, the files are in C:\Users\NotMyUsername. I suspect this is the reason that it is asking for permission.
My user is administrator on this PC
Changing the permissions of the folder has stopped it from asking for permission and seems to have stopped the problem.
Interestingly, the files that I renamed earlier now seem to have actually changed their names in windows. I am pretty sure I haven't restarted since then so I wonder if this was all due to some weird delay in windows renaming the files.
geposted Tue 27 Feb 18 @ 11:48 pm
