Topic: Reversing a track
I'm sure most of you are aware of this, but if you right click the play button on any deck, it reverses the track that's playing. Now, I'm using a Mixtrack Pro III, and I want to be able to do this directly because it could lead to interesting effects before a 'drop'. Is this possible at all?
geposted Sun 25 Feb 18 @ 7:38 pm
The script is either
reverse
Or
dump
geposted Sun 25 Feb 18 @ 7:43 pm
I guess you could change the PLAY button on your controller from
<map value="PLAY_PAUSE" action="var 'shift' ? play_stutter : play_pause" />
to
<map value="PLAY_PAUSE" action="var 'shift' ? reverse : play_pause" />
This way, SHIFT+PLAY would cause the track to go in reverse
geposted Mon 26 Feb 18 @ 9:22 am
to
Solid, thanks guys.
geposted Mon 26 Feb 18 @ 7:23 pm
