Could someone make a Pad Page like the DDJ-SB3 Pad Scratch
Then we could be a little ahead of the game, and already have the new function, even before this new controller is mapped
... and of course for every controller :)
To me it looks like just a list of recorded jog wheel movements
I've made this and tried it with different move and wait lengths, but it has to be a little better than that:
down ? touchwheel_touch on & scratch -200ms : scratch +200ms & repeat_start 'wait' 50ms 1 & touchwheel_touch off
geposted Thu 01 Mar 18 @ 11:44 am
That will be an awesome add if it's possible..Cuz I just looked at the video and I was like "nooo waaay". And now I want to buy an SB3..
Downside is that I just recently purchased an SR 2
geposted Thu 01 Mar 18 @ 2:29 pm
Scratching DJs will be up in arms now though .........
geposted Thu 01 Mar 18 @ 2:36 pm
No doubt :)
geposted Thu 01 Mar 18 @ 4:02 pm
Scratch dj here, yes & no (up in arms) yes because what it can do will be rinsed, no because scratch isn't perfectly quantized, the feeling of the performance is in the syncopation.
Then there's the xf work.
Also given that vdj's scratch command is time driven and not beat driven it will be hit and miss,
(Can't say how the sb3 works)
Kind of like figuring out your car's speed by the engine's rpm, possible if you factor; gear, drag, traction, load, engine efficiency.
I've got the tools and like a challenge but I doubt I'll publish owt on this one.
geposted Thu 01 Mar 18 @ 8:24 pm
Glad you like the challenge though :)
geposted Thu 01 Mar 18 @ 10:50 pm
It will probably be better to write a plugin for this. That would be much more accurate, beat synced and could also take care of volume to emulate xf movement
geposted Fri 02 Mar 18 @ 3:47 am
geposted Fri 02 Mar 18 @ 9:50 pm
geposted Wed 07 Mar 18 @ 7:09 pm
DjYayay2014 wrote :
https://youtu.be/NuoyPMY6sOc
Wow ! Impressive ! I should give a try for fun when I'll have time.
geposted Wed 07 Mar 18 @ 7:17 pm
Perfect!!!!!!
geposted Tue 20 Mar 18 @ 2:19 am
Thanks to Klausmogensen....all the tutorials..
geposted Tue 20 Mar 18 @ 2:33 pm
If I understood DJDad correctly, the Scratch Pads aren't actually an effect.
They are just "pre-recorded" midi messages, that every software could interpret and move the jogs and CF according to the messages.
But maybe I'm entirely wrong.
geposted Tue 20 Mar 18 @ 10:54 pm
Yes, you understood well. But until we implement something similar or provide an action/tool to reproduce (or even record your own ones), Klaus suggests a workaround with something that sounds like a scratch.
geposted Tue 20 Mar 18 @ 11:18 pm
please someone can help me to mapper the pioneer ddj sb3 with the virtual dj 8? i connect it an is not working...?
geposted Mon 21 May 18 @ 10:45 pm
Build number?
geposted Tue 22 May 18 @ 12:07 am
You need the latest Build 4291 http://www.virtualdj.com/download/index.html
and a Pro or Plus Home license to get it fully working or else your DDJ-SB3 will only work for a limited time.
geposted Tue 22 May 18 @ 6:51 am
will not work on mac can someone make some maybe like just 8 to start with as a plug-in that will work with mac
geposted Thu 31 May 18 @ 6:55 pm
take a look at VDJ2018 ;o))
geposted Thu 07 Jun 18 @ 2:57 pm
not Sure what you're asking me to go look at
geposted Fri 08 Jun 18 @ 5:25 am
