已测试,一旦连接VIRTUALDJ之后,机械转盘光标狂转,使用其它软件没有任何问题,比如Serato 和 Rekordbox,请帮我处理一下。
geposted Wed 07 Mar 18 @ 1:23 pm
This user says the VirtualDJ connected CDJ2000Nexus device,jogwheel VFD display screen (Indicating needle) speed is abnormal(Fast rotation),other dj software no any problems.
geposted Wed 07 Mar 18 @ 1:45 pm
Maybe the track loaded is a mix? (longer than 60 minutes)
Otherwise I'd guess he should make sure he is using the factory default mapper, as it might be something wrong when changing the mapper.
geposted Wed 07 Mar 18 @ 2:41 pm
