Forum: Addons
Topic: (DIN) Dancehall 1
geposted Thu 08 Mar 18 @ 12:45 pm
lincol2PRO InfinityMember since 2011
Yes man good stuff!
geposted Fri 09 Mar 18 @ 1:47 am
AsTheDJPRO InfinityMember since 2008
can't close window I have mapped my shift+esc to crash and that the only way to remove it when shift + esc it don't crash it just remove the large window then the small window is there, then I hit ok, for some Dj may know what to do.
geposted Thu 14 Jun 18 @ 8:03 pm
You cant edit the sample pack downloaded, as is. You need to unzip it first.
The unzipped version of the sample pack, you are free to edit, rename, apply changes etc.
(The zip-file itself is left untouched by design, so that the sample pack is kept as intended. For your own edits simply unzip the downloaded pack :) )
geposted Thu 14 Jun 18 @ 9:37 pm
