I've been trying different things to try and make the level about the same on all decks that I use and I'm not really to successful. Any help would be greatly appreciated. BTW I am not using any external controller.
Thanks...
Thanks...
geposted Fri 09 Mar 18 @ 9:36 am
I adjust my mp3 to the same general gain level (96db) using MP3Gain - this should however not really be necessary for use in VDJ
I then use "auto" for auto gain setting - not "remember", because I may adjust the gain manually on a track once in a while for effect while mixing
geposted Fri 09 Mar 18 @ 9:46 am
Exactly the same as me.
I play mostly videos at my gigs now which can't be ran through MP£Gain, but the inbulit VDJ autogain set to "auto" works perfectly.
geposted Fri 09 Mar 18 @ 10:02 am
