The VirtualDJ Remote app had been running fine on my Note 8 earlier running Android 7.0. However upon the Android 8.0 update the app is simply crashing on the start up. Any solution?
geposted Mon 12 Mar 18 @ 12:24 pm
Have you tried uninstall and reinstall?
geposted Mon 12 Mar 18 @ 1:05 pm
As far as I am aware the Note 8 Oreo update has not been rolled out by Samsung yet.
Where did you get it from as that may be part of the issue?
geposted Mon 12 Mar 18 @ 1:36 pm
Working here with Oreo 8.1 on an OPO.
geposted Mon 12 Mar 18 @ 3:28 pm
Hi groovindj,
Yes!! The app is running smooth once again upon the uninstall and reinstallation. Thanks for the solution : -)
Varsham
Posting links for dodgy software is a Bozo no-no
Varsham
geposted Fri 16 Mar 18 @ 9:17 am
